Lead Capture Form - Required Fields and Order
Discussion in 'Infoway WordPress Theme' started by tsays, Feb 14, 2013.
  1. tsays
    tsays New Member
    Hi -
    Is there a way to make a field optional?
    Also, how can I adjust the order of the fields?
    Thank you,
  2. thore
    thore New Member
    An answer from the developers would be great, since i would also like to know how to make fields optional
  3. Piyush
    For the field optional issue,
    go to the infowway-front.php file (Theme directory > functions directory > infowway-front.php) present in your Theme directory and remove the code given below from the that file as shown in the image given below.
    class="required requiredField email" required
    See the image for reference.
    This will make the field optional.
    For the field order issue,
    Go to the Appearance > Custom Lead Capture Form panel in your dashboard and delete all the fields and recreate all the field in your order.
    This will solve your order issue.
