I have removed the lead capture box by placing text or by using blackstudio to insert html or visual editor, but the line above the location always comes up orange. i am using the blue layout
It is not possible to change its color because it is an image not a color If you want to change its color then, Go to images directory present in your theme directory and replace your image with present line image or edit it. The name of image is "titlesep.png" Note:- Use same name for your edited image and remove the current image.
Its not an image, I am inserting a google map into the side bar. Where will i find the images directory in my theme directory? Because when i look at my dashboard i dont see it.
Hello, You will not get theme directory in your dashboard. You can find the image through FTP. Open your Theme directory (through FTP) > image directory, you can find that image in that image folder.
Ok, now you speaking well over my head. I bought this because it was blue and not orange. I really like the set up, but i dont know how to oen something through an ftp. I dont even know what that means
Hello, Please provide the following information listed below so that we will do it for you. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected]
