Lead Capture - Not a Tight fit on pages
Discussion in 'Blackriders WordPress Theme' started by ronaldsinai, Sep 28, 2015.
  1. ronaldsinai
    ronaldsinai New Member
    The lead capture form on the side of my pages looks odd because the form droops down well below the "Get Funding" button. See my attached image "leadcapture trouble" below to see what I mean.
    For the leadcapture on the homepage (which you can find here) does not have this problem. The problem only exists for leadcaptures on other pages/posts on the website.
    Thank you in advance for the help!
  2. nitin
    nitin Guest
    .sidebar .signinformbox_wrapper {
        height: 278px !important;
    Nitin
  3. ronaldsinai
    That worked, but now there's a scroll feature on the lead capture for no reason. Is there a way to fix this? Thanks.
  4. nitin
    nitin Guest
    Thank you for informing us the issue.
    .mCSB_scrollTools .mCSB_draggerContainer {
           display: none !important;
    Nitin
  5. ronaldsinai
    Hey,
    It only got worse. Now the leadcapture on the homepage is not even AT ALL. Check it out here: fundmylawsuitnow.com.
    I need to get this fixed ASAP, please.
    Thank you
  6. ronaldsinai
    Never mind, I fixed it. Thanks anyways.
