Lead capture not forwarding leads to my email
Discussion in 'Blackriders WordPress Theme' started by ronaldsinai, Dec 2, 2015.
  1. ronaldsinai
    ronaldsinai New Member
    This is has been working for me perfectly for the past year, but for some reason the leads are no longer being redirected to my email.....
    I double checked my settings at Appearance ---> Theme Options ---> Lead Capture Settings and I have my email address spelled out correctly.
    Please help ASAP. Thank you
    I have just visited your site and would like to inform you that- You are using BlackRider version 2.1.1 in your WordPress whereas, version 2.1.3 is available in members area,
    You may go through the changelog file provided in our theme.
    If you haven't customized your theme's source code then, you are requested to download a fresh copy of latest version of this theme from members area and upload it to your website.
    Here are the steps involved in doing so:
    Download the BlackRider Pro theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder blackridertheme like blackridertheme_new,
    Again, you would need to create a zip file of that renamed folder (say: blackridertheme_new.zip),
    Then, activate your theme,
    This way you can install and activate your updated version in your site,
