Lead capture not working - Appointway
Discussion in 'Appointway WordPress Theme' started by fysio01, May 11, 2014.
  1. fysio01
    fysio01 New Member
    Denmark
    Hi´
    I have tried to use the lead capture form i the Appointway theme, but it does not work.
    When I try to test the form in Chrome, by entering text into the predefined fields the browser automatically jumps to the belowe page:
    http://www.fysio-logic.dk/WWW.FYSIO-LOGIC.DK
    When I test the form in Internet Explorer it is not possible to enter text into the fields => nothing happens when I point the mouse to the predifined fields and the same when using the keyboard.
    What can I do ?
    Second issue:
    Is it possible to change the colour of the lead form box - currently it is dark grey and I would like it to be more discrete ?
    Fysio01
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check your issue.
    2. Go to images directory present in your theme directory and replace your images with present form background images or edit it.
    The name of images are
    "form-bg-top.png"
    "form-bg-center.png"
    "form-bg-bottom.png"
    Gourav Shrivastava
