Lead Capture not working
Discussion in 'Blackriders WordPress Theme' started by dmelo1432, Mar 19, 2015.
  1. dmelo1432
    dmelo1432 New Member
    I have sent test leads through the form and all they go to is the lead capture page on wordpress but they dont seem to be emailed to me. Another question I have is how to remove the Inktheme facebook like box and put my own and remove the inktheme backlink at the footer?
  2. sameerwalkar
    sameerwalkar Guest
    For email kindly check have you set up email id as shown in the image below:
    To remove the Facebook like box option you need to go to widget area and then follow the steps mentioned in image:
    3. To remove the footer InkTheme backlink follow steps:
    Sameer
  3. dmelo1432
    I'm trying to configure the lead capture form so I get emailed if I get a lead. I put in my email address but when someone fills the form I don't get emailed. I only see that they filled the form once I login into word press and look at leads. I want to be emailed the lead.
  4. sameerwalkar
    sameerwalkar Guest
    Follow the steps mentioned below:
    Sameer
  5. dmelo1432
    I did exactly as you mentioned and I'm still not receiving the email.
  6. sameerwalkar
    sameerwalkar Guest
    Kindly send your URL.
    Sameer
  7. dmelo1432
  8. sameerwalkar
    sameerwalkar Guest
    This Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Sameer
  9. dmelo1432
    I sent the information yesterday but did not receive a response.
  10. sameerwalkar
    sameerwalkar Guest
    Sorry for the delayed response. We have checked at our end and done some changes, its working fine now. Kindly check at your end, let us know if its working.
    Sameer
  11. dmelo1432
    I tested the lead capture form and waited but never got an email sayin I had a lead. This is a nice theme but it needs to work as I depend on it to make a living.
    David
  12. sameerwalkar
    sameerwalkar Guest
    Hi David,
    Sorry for the inconvenience caused. The error that was occurring was due to some domain related issues in mail header function. We have done some modifications in it now it should work at your end also. Kindly check and let me know.
    Sameer
