Lead Capture on Blackrider
Discussion in 'Blackriders WordPress Theme' started by marketingtypeguys, Jan 21, 2016.
  1. marketingtypeguys
    marketingtypeguys Member
    Hi -
    I tried to remove the lead capture for with this CSS
    .caption {
    But it didn't work. Is there something else I can do to remove this?
    website is www.saharaair.com
    Try below code for once,
    .caption {
        display: none !important;
    And if still will not resolve your issue, kindly suggested to clear your cache and check after that..
    greatscottfilm likes this.
