Lead capture side
Discussion in 'Blackriders WordPress Theme' started by nirit1, Jun 18, 2014.
  1. nirit1
    nirit1 New Member
    Hi
    1. How can I change the side of the lead capture (so it will appear on the left side of the screen)?
    2. How can I remove the Ink link to facebook and add mine ?
    3. How can I remove the blog completely from the homepage ?
    Thank you
  2. nirit1
    nirit1 New Member
    Pls your help....
  3. Nitesh
    1) Paste this code in Custom CSS
    .caption {
    left: 15.65%!important;
    2) You need to add your fb like box at the
    Appearance > widgets > Home Page Right Feature widget area
    Follow link given below to generate like box.
    http://www.inkthemes.com/bring-more...facebook-like-button-and-like-box-plugins/04/
    3) For this open "front-page.php" file and remove code from line number 207 to 245. You can add any other content there.
    Nitesh Raghuwanshi
  4. nirit1
    nirit1 New Member
    Thank you.
    1. The code for the lead capture:
    .caption {
    dose not change it's side to the left, is the code correct ?
    2. How can I make the top header narrower ?
    Thanks again
    Nirit
  5. Nitesh
    Hello Nirit,
    1) This css code is working at our side. please share your website link. So that i can check it.
    2) Paste this code in Custom CSS
    .header_container {
    padding: 10px 0;
    Nitesh Raghuwanshi
  6. nirit1
    nirit1 New Member
  7. Gourav
    .flexslider {
    width: 100%;
    height:100%
    .caption {
    right: initial;
    Gourav Shrivastava
  8. nirit1
    nirit1 New Member
    Thanks for the quick response !
    Is it possible to keep the slider small, on 1/2 screen ( I actually do want the slider smaller.. :))and put the lead capture all the way to the left ? so it won't be on the top toolbar (even that it won't be on the pic.)
    Now it looks like this :
    http://69.195.124.135/~niritcar/
    Thank you!
    Nirit
