Hi, is it anyway the reader can contact directly to poster by Lead System. In order words, the lead message will be send to poster's email. Thanks
Hello, Yes, there is an option in Dashboard-->>classfied settings-->>Theme Options-->>ad settings-->>Lead Capture Form On/Off. By enabling the lead form it will get appeared on the single listing detailed page, so that one can directly contact. Hope it will solve your issue. Let me know for further doubts.
It doesn't work for me. I already turn On Lead Capture Form. Is there any way I can find the errors? I think my hostings have some problem with sending email, I used WP-Mail-SMTP instead, but I'm not sure whether it affect Lead Capture Form or not. 1 more question, is it any way I can add [State] Title for the Ads ( instead of just Title) for multiple location? Thankss.
Hello brenda12, Thanks for your prompt response. As per your queries.: 1. I have tested at our end it's as if now working fine. If it's something with your hosting mail issue, I would suggest you to kindly check so that i can assist you further accordingly. 2. Could you please able to provide some edited screenshots. If you are unable to create screenshots you can use http://www.screenpresso.com/ let me know.
I tried with different hosting and the result is the same. Look into the code, I see the Lead Message is only available for premium ads? Is it anyway I can change it for all ads? Thanks
I have successfuly received the lead message for premium ads, I want to open this option for free user, How can I do it? 1 more thing, the email I receive not show the name of use, it has like: Dear [%user_name%], You have got new lead on your ad Is it any thing I can fix on cc_email_notification.php?
Hello, I have visited your site and as if now its working fine. Kindly refer the below image for reference. Kindly recheck at your end, if still issue persists let me know.
Hello, If you wish to provide a default image for the post without image then for that some source code customization will be required. Please provide the following information listed below. This Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected]
Hi Sammer, How can I create a permanent link for specific taxonomy? For example, if there is a state such as Texas, California,.. I want to create a link for all ads in state Texas Moreover, can I hide specific field for specific category? Thanks for your support.
