Lead Capture Widget Position Adjustment
Discussion in 'Lead Capture WordPress Plugin' started by cbshanley, Mar 16, 2016.
  1. cbshanley
    cbshanley Member
    You were able to move my Lead Appointment widget to the top of the sidebar on the Home page. But it wasn't done with the placement of widgets (hard coded?). Right now, it's too far to the top. I'd like to get it to line up on page like the one does on the About Us page does. It's 46 px from the top. I tried doing that with CSS, but it moved both of them down and messed up the position of the one on the About Us page.
    I tried to add a Visual Editor widget about it on the Home page sidebar and create blank spaces to move it down, but the widgets don't position properly.
    Can you fix it?
  3. cbshanley
    cbshanley Member
  4. cbshanley
    cbshanley Member
    Ideally, I'd like to place the Search widget above it, but still have the top of that one line up horizontally with the top of the text to the left of it.
  5. priya
    div.appointment_wrapper {
        margin-top: 46px;
  6. cbshanley
    cbshanley Member
    Thanks, Priya. But I'd still like to move the search widget above the Lead Capture widget.
  7. priya
    I have tried to access your dashboard but it seems that you have changed your credentials...
    So please send us your credentials at [email protected].
  8. cbshanley
    cbshanley Member
    Hi Priya,
    You have access to the dashboard again.
    Mark
  9. nitin
    nitin Guest
    Hello Mark...
    I have checked your dashboard and it seems that you have not provided admin credentials as I am unable to do any changes over there....
    So you are kindly requested to provide us your admin credentials so that I can do the needful changes...
    Nitin
  10. nitin
    nitin Guest
    Hello Mark...
    Nitin
  11. cbshanley
    cbshanley Member
    Hello Nitin,
    Do you still need the admin credentials? I've sent them in three or four times.
    Mark
  12. nitin
    nitin Guest
    Hi Mark,
    We have successfully received your credentials and our developers are working on it.
    We were facing a little issue as many-a-times the SFTP connection gets terminated.
    However, we are still hopeful to get the things done very shortly as per your requirement.
    Nitin
