Hi, on www.glaszetteralkmaar.nl I have the Dutch translation. And the E-mail field is required so that if one will press the 'send' button you will not be able with out putting down your email adress. For www.glaszetterzoetermeer.nl It will send the message even if it is empty. And although I put the translation in the js file it does not translate. Can you help me out. I want the lead form on the homepage of zoetermeer to work the same as on Alkmaar. Kind regards. Bart
I fixxed the translation problem! I also read in other posts that there are some difficulties with the required fields? Is that right? As you can see I managed to do that on www.glaszetteralkmaar.nl and I did not do anything with the code. Perhaps you lost this function with an update? Second questions still stands: How can I get the message ' this field is required' when people press the send button without filling in any details. ciao Bart
Required field issue resolved, Download theme from your members area and upload it, This will solve your issue. Login here: http://inkthemes.com/members/member/index
