When displaying the Dashboard, the last option says "Leads Capture". When you click on it, you see all of the leads that customers have entered. However --- the title of all the leads says "My Subscriptions" and the description under that title says: "Note: You would not be able to see subscriptions of free listings. Your listings must be paid to view all subscriptions." --- (mentioning "subscriptions" two more times). Shouldn't all references to "subscriptions" be changed to "leads"? It would be a lot less confusing. Thanks, - Cary
Hi Krish - just following up on this. There have been two minor updates since you said this would be done in the next update. Can it still be done?
I just updated my theme to the latest version, and I am still seeing the use of the word "subscriptions" throughout.
FYI, I found the page where you can edit the wording alluded to above: geocrafttheme>text-domains>dashboard_path.php, line 31
Nice work ehause just to clear up though the path to the file (access through ftp) /wp-content/themes/geocrafttheme/library/text_domains/dashboard_path.php and depending on your editior it may not be on line 31, the line you need to edit looks like this Code: define('NO_SUBS_FOUND',__('WRITE WHAT YOU WANT IT SO SAY HERE.',THEME_SLUG));
