Leads Capture display error
Discussion in 'Blackriders WordPress Theme' started by lalimo, Dec 29, 2015.
  1. lalimo
    lalimo New Member
    Leads capture showing error on slider.I contacted to hosting company siteground to find out if the problem is on their end to resolve,but they said that's the theme issue. Can you please check the site toplimoservicelosangeles.com and let me know? I did pre much some work by creating 41 pages and ready to upload the content and don't like to remove the theme and make it fresh install.
    Please help to resolve the issue.
    I have checked your site and would like to inform you that we didn't find any error over there.
    Kindly check..
  3. lalimo
    lalimo New Member
    Thanks for reapply
    I already fixed it.Can you please tell me how can make the text under each future images symmetric?Also its loading very slow
  4. nitin
    nitin Guest
    .feature_inner_box h2 {
    min-height: 57px;
    Hope this helps...!
    Nitin
  5. lalimo
    lalimo New Member
    Hello
    I was following to previous tread on forum to make the Home Page Leads
    Form Redirect to Custom Thank You Page.By following to your direction
    by editing blackrider-front.php file by adding custom thank-you
    page url,but it doesn't respond and even not sending the email address I
    filled on leads capture setting on theme option.
    Also dashboard admin (to customize the theme) is loading very very
    slow (I never experienced this issue with other themes). I switched
    the hosting companies to make sure its not a
    hosting problem,but loading problem remains the same and no difference.
    Can you please check the site and help me to resolve the issue?
    I sent an email to [email protected] with login credentials.
  6. priya
    Thanks for the details..
  7. lalimo
    lalimo New Member
    How soon?I am still waiting.Please get back to me as early as you can.
  8. priya
    We have forwarded your issue to our developer team and will get back to you soon..
