Leads Capture form doesn't work
Discussion in 'Blackriders WordPress Theme' started by threadesign, Dec 23, 2015.
  1. threadesign
    threadesign New Member
    I have setup my website: blindsvancouverwa.com and for some reason the form doesn't capture information and does not forward anything to email.
    Could you please provide us your dashboard credentials at [email protected] along with this thread link as well so that we can figure out the issue and able to resolve that?
  3. songbirdmama
    songbirdmama New Member
    Was this issue resolved? I am having the same issue with littlesongbirdmusic.com.
  5. lalimo
    lalimo New Member
    I just sent you inquiry to [email protected] in regards the same issue I am having on my site toplimoservicelosangeles.com
    I will appreciate your response to my email.
  6. priya
    Ok Lalimo,
    Thanks for the details..
  7. songbirdmama
    This is the BlackRider theme, so the lead form was in the /functions/leads_form directory of the theme, not in the plugin. Changing 'mail' to 'wp_mail' was necessary, but the email header also had a problem. Removing the header got the email notifications to work, but the leads are still not being inserted into the database.
    Here is the code in the leads_class.php file that appears to be broken:
    PHP:
    public function savetodb() {
            global
    $wpdb$inkthemes_table;
    $sql "SELECT * FROM $inkthemes_table WHERE  rand_value =$this->randvalue";
    $value $wpdb->get_row($sql);
            if (!
    $value) {
    $query $wpdb->insert($inkthemes_table, array(
    //$wpdb->insert($inkthemes_table, array(
    'name' => $this->lead_name,
    'leadform1' => $this->form1,
    'leadform2' => $this->form2,
    'leadform3' => $this->form3,
    'leadform4' => $this->form4,
    'leadform5' => $this->form5,
    'leadform6' => $this->form6,
    'leadform7' => $this->form7,
    'leadform8' => $this->form8,
    'leadform9' => $this->form9,
    'date' => date('Y-m-d'),
    'rand_value' => $this->randvalue
    Any suggestions? Thanks!
  8. priya
    OK!!
    Let me check this at our end and will get back to you soon...
