Leads capture form - How to make a field that is NOT required?
Discussion in 'Infoway WordPress Theme' started by lcbrown, May 17, 2013.
  1. lcbrown
    lcbrown Guest
    I've customized the leads capture form with my own fields, but there's one field I don't want to be required. It seems that all fields are required by default. Where can I change this? Thanks!
    Go to functions > infowway-front.php present in your theme directory and remove the code given below
    class="required requiredField" required
    Sending image for reference
