Hi. Is there a way of making the big black header, and button, on the leads capture form, smaller and a different color? Thanks Drew
It is not possible to change its color and size because it is a image, If you want to do so then, Go to images directory present in your theme directory and replace your image with present header and submit images or edit it. The name of image is 1. "formheadbgnew.png.png" 2. "submit-button.png" Note:- Use same name for your edited image and remove the current image.
also, is there a way to remove the number and message fields, so that it shows just the name and email?
1. You can use any dimension image that you want to show there. 2.Go to Appearance > Custom Leads Form and add and remove the fields from there as per your requirement.
