Leads capture not appearing on homepage
Discussion in 'Infoway WordPress Theme' started by elenhardt, Mar 28, 2016.
  1. elenhardt
    elenhardt New Member
    The leads capture form isn't appearing on our homepage:
    http://normsfarms.com
    Please help.
    Thanks!
  2. nitin
    nitin Guest
    It seems that you have not properly configured the Lead Capture widget from the widget area.
    After installing and activating the Ink Leads Capture Pro Plugin, just go to (Appearance -> Widgets) from your dashboard. Then from the list of available widgets, just select the 'LeadsCapture widget' and drag-and-drop it to the "Home Page Right Feature Widget Area" on the right as shown in the screenshot given below.
    This will display the leads capture form on the homepage.
    Nitin
