Leads capture not working
Discussion in 'GeoCraft WordPress Theme' started by cayenne, Mar 25, 2015.
  1. cayenne
    cayenne New Member
    I have WordPress 4.1.1 running Geocraft V2 theme. I have all of the lead capture and captcha settings enabled except for Free listings, which is disabled. I am receiving the emails from both the website lead capture and the sample listing I set up, but the leads are not showing in the Dashboard - Geocraft Settings - Leads Capture. If the system is supposed to capture all leads, even the ones sent to the business owners, I'm not receiving those either via the Dashboard.
  2. sameerwalkar
    sameerwalkar Guest
    Kindly Check your mail we have sent a mail
    Sameer
  3. cayenne
    cayenne New Member
    I have responded. Thank you.
  4. cayenne
    cayenne New Member
    Sameer, I can download a .csv file from Geocraft Settings - Import Export - Export to CSV from listing
    However, under Geocraft Settings - Leads Capture nothing is shown there.
    I have set up a test account with another email and went through the process of email the business listing owner. All of the emails are being delivered correctly but the Leads Capture page shows nothing
  5. sameerwalkar
    sameerwalkar Guest
    This Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Sameer
  6. cayenne
    cayenne New Member
    Email sent Sameer. Thank you.
  7. sameerwalkar
    sameerwalkar Guest
  8. cayenne
    cayenne New Member
    Sameer, use same credentials.
  9. sameerwalkar
    sameerwalkar Guest
    Kindly check your email
    Sameer
  10. cayenne
    cayenne New Member
    Sameer,
    I will also send this reply to the email from Naveen.
    I have contacted my hosting company resellerspanel.com. They disabled ModSecurity entirely for my domain, that did not correct the problem. This is their reply:
    "We have double-checked the Database of the website and all tables appear to be intact, however we are not familiar with the theme in question and it would be best if you could contact the developers so they can try re-installing the theme for you now that ModSecurity has been disabled for the domain."
    I re-installed the theme and WordPress and that did not correct the problem.
    I am receiving both the new user registration and listing subscription notification emails but the data is not appearing in the Leads capture page.
    Steve
  11. cayenne
    cayenne New Member
    Any update on this Sameer? I have had to delay the launch of my website until this is corrected. :(
  12. sameerwalkar
    sameerwalkar Guest
    We have forwarded your issue to our development team, as soon as I get any update I will let you know. Thanx for showing co-ordination and patience
  13. cayenne
    cayenne New Member
    Sameer, I got tired of waiting. I deleted my entire hosting account and started my website over. Problem solved. Thank you.
