Leads Capture Page of Results
Discussion in 'Blackriders WordPress Theme' started by mobilitymojo, Feb 6, 2014.
  1. mobilitymojo
    mobilitymojo New Member
    The leads capture results page is showing a bunch of columns I'm not using. I want to eliminate those columns so the table is easier to read. Please tell me how to format the Leads Capture Table of results from within my WordPress Dashboard. (I'm not referring to the .cvs that is downloaded as I do not want to have to download the data every time I review the leads.).
    Thanks.
    Patsy
    www.tedsmithlawgroup.com
    Could you please explain your problem with the help of screenshot, what you want to do. So that we will provide code for that.
    Gourav Shrivastava
  3. mobilitymojo
    I'm only referring to the leads capture report page. This is what I see:
    Leads Capture
    Below are the messages received from your Visitors including their contacts details.
    NameEmailNumberMessageLabel5Label6Label3Label4Label5Label6DateAction
    Most of the columns are not needed. I can't seem to get rid of "Labe5", "Label6", etc.
  4. mobilitymojo
    The screenshot is below. I need to be able to modify the format of this page.
  5. Nitesh
    For this download file attached and replace it with your existing "theme-page.php" file
    File location
    blackridertheme\functions\leads_form\themes-page.php
    Nitesh Raghuwanshi
  6. mobilitymojo
    Will this change anything else on my site - like custom CSS styling options I have set?
  7. Gourav
    No, It does not change any thing else except the format of lead capture admin panel.
    Gourav Shrivastava
