leads capture
Discussion in 'Infoway WordPress Theme' started by azgirl, Apr 28, 2013.
  1. azgirl
    azgirl New Member
    If you remove the leads capture, what widget can you put in area, can you put a video. thanks for this wonderful forum
    Yes you can add video in place of lead capture form.
    Just select text widget and add your video embed code there.
    Check image foe reference.
  3. azgirl
    azgirl New Member
    thank you Nitesh, that helps a lot. azgirl
