Lightbox unavailable
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by chmchm, Feb 23, 2015.
  1. chmchm
    chmchm New Member
    Can you recommend a way to include it, or is there another lightbox that you recommend?
  2. Pramod
    Pramod Guest
    Hello !
    For product page we have no recommendation for light box, But you can try any plugin which is compatible with woocommerce plugin.
    You can ask this from woocommerce support may be they will recommend a better plugin which work with woocommerce without any issue..
    Pramod Patel
