Line Spacing Issue
Discussion in 'Local Business WordPress Theme' started by 1stopnonprofitshop, Aug 10, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Is there a code I can add to CSS to and a little more spacing between lines? They seem very tight together. I manually corrected this for the Social Media page, but don't want to have to go edit code for each individual page if I can just use a general code.
    www.1stopnonprofitshop.com
    For that, code is given below..
    .fullwidth p {
        line-height: 30px;
  3. 1stopnonprofitshop
    That didn't seem to help the spacing issue.
    Please clear your cache and check the result after that..
    Or, you can try below code as well.
    p {
      line-height: 30px;
    NOTE: Change the numeric value as per your requirement..
  5. 1stopnonprofitshop
    Neither one of those codes seem to be working. I tried both, cleared my cache, and it still didn't make any changes. I wonder if something is blocking the code.
  6. priya
    Would you please deactivating all plugins to see if this resolves the problem. If this works, re-activate the plugins one by one until you find the problematic plugin(s).
