Link color, stacking dropdown arrows and upgrading
Discussion in 'ButterBelly WordPress Theme' started by paitapaino, Mar 21, 2014.
  1. paitapaino
    paitapaino New Member
    Hello, I was wondering if there's a possibility to change the link color in posts / articles without affecting the general layout of (for example) the static front page? In ButterBelly theme the links won't pop out in anyway from the main text of the article as they are styled normally and color is black.
    Also it seems that the multiple arrow thing appearing after mouse-over on the drop-down menu is persistent on Google Chrome. I tried to clear cache and they still stack on each other. With IE I'm not encountering this problem.
    Also if I want to upgrade the Butter Belly theme from my wp dashboard, my Wordpress says there is already a folder named wordpress. Should I just overwrite the folder manually or will this erase all my theme options? (ps. I don't have any custom code on my site)
    http://www.ouluntaiji.fi/
    Paste this code in Custom CSS
    a{
    color:blue;
    2. For your second issue download updated version of theme from your members area and upload it. This will solve your issue.
    Login here: http://inkthemes.com/members/member/index
    3. In downloaded theme, You will get a zip file, Extract it, rename the theme directory and again make it zip and upload it.
    Gourav Shrivastava
  3. paitapaino
    Wonderful, it's like all my problems have disappeared. ;)
    Thanks a lot, love your Company!
