Link to products
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by aster media, Jun 18, 2015.
  1. aster media
    aster media Member
    Dear Praveen.
    My client wants the product section not to be shown on the homepage, but to be navigated to from the menu. Is it possible to create a menu link or something to the product section? You already advised me how to delete the product section from the homepage, so that part is covered.
    If not possible, the idea is to create a subdomain for it. But that is obviously much more work as I need to copy the entire webshop.
    Thanks in advance for your insight,
    Steven
  2. praveen
    praveen Support Staff
    Don't worry!!!
    There is no need to do anything extra to link product page in Menu.
    Whenever you activated "Woocommerce Plugin" there comes an option in the dashboard ( top section ) to install Woocommerce Pages.
    Install it and after configuring it you will be able to see "Shop" item in the menu bar which will redirect you to product page.
    Watch the video for more understanding :- http://screenpresso.com/=GaVwb
    Hope it will resolve your issue.
    Praveen
  3. aster media
    aster media Member
    That's a relief. However, I did not install Woocommerce Pages when I activated the Woocommerce Plugin and I do not see the option in the dashboard anymore. I searched for the plugin but it probably is not available by itself. What can you suggest?
  4. praveen
    Follow these steps:-
    1>Go to the "System Status" tab on Woocommerce
    2>Click on the "Tools" tab at the top of the page
    3>On that page, the sixth option down is called "Install pages".
    4>Clicking that will "install WooCommerce pages. Pages already defined and set up will not be replaced."
    Praveen
  5. aster media
    aster media Member
    Eternally grateful to you, Praveen. Thank you.
