Links not saving in theme options
Discussion in 'Appointway WordPress Theme' started by sfmsfm, Dec 8, 2013.
  1. sfmsfm
    sfmsfm Member
    I have changed and saved a hundred times and no matter what I put in how I put it in this will not save :(
    Link for First slider
    old url (I have tried changing and deleting the entire url)
    Mention the URL for First image.
    the url will not change - I make this change and click save then I tried - deleting so it was blank and it returns (reappears/comes back as though I have not done anything) after I click save :(
    it is the same for slider options, home feature area, social icons
    basically everything in the
    Appointway Theme Pro Options
    section :(
    this is urgent as the site is now live and in press releases etc and I leave for holidays in a few days so need to change these links asap please
    I have tried several times
    you have the login details as you have helped me with a few things in this theme
    We have checked slider link section on your dashboard and it is working fine.
    I think you are putting wrong URL link in the slider link section.
    Use correct URL link for this section.
    For example like http://www.inkthemes.com
    It will solve your issue.
  3. sfmsfm
    sfmsfm Member
    hmmmmmmmmm I did say that I had completely deleted all url so it was blank so not sure how your answer fits that :) lol
    I see you managed somehow to remove the /site I will go and change them and see if they keep the new urls
  4. sfmsfm
    sfmsfm Member
    nope it didn't keep it :(
    I will tell you step by step what I do and you tell me what I am doing wrong..........
    I go to theme options
    I click on slider settings
    I select the text in the box labeled Link for First slider
    I hit delete it is now blank
    I copy and paste a url from one of my pages in my website that is live
    I go down to the save button
    I click save all changes
    the page refreshes and I am taken to the themes page
    I have to go and click the theme options
    I see the url is not saved
    so what out of my steps above am I doing wrong please tell me
  5. Piyush
    Could you please try it with another browser because it is working at our side.
    If it is still not working at your side then please provide us the URL links for all respected slides so that I can check it again.
  6. sfmsfm
    sfmsfm Member
    you didn't say what it was that I did wrong?
    but to answer your question slider 1 I put this url in http://www.scarboroughwebdesign.co.uk/category/news/ as you can see that is not the link that it kept
    I haven't done the others, once I can do this I will do them just can't see what it is that I am doing wrong
  7. Piyush
    I have pasted the URL given above by you in the first slider link section of your dashboard and it is working fine, you can check your site.
  8. sfmsfm
    sfmsfm Member
    so you did what I did but yours stayed and mine didn't!
    glad I didn't do anything wrong as frustrating as that was
    anyone reading this I know what the problem is..........
    it is a conflict with firefox 25.0.1 it won't save your settings I had to use IE for it to save!
