Listing category does not show up
Discussion in 'GeoCraft WordPress Theme' started by abewest, Apr 1, 2017.
  1. abewest
    abewest New Member
    I copied these ?s from an old post as they figured it out on their own so there are no answers for me.
    Have uploaded and installed latest version of GeoCraft 2.0.8 and am TRYING to make it work but I have a few questions:
    1) On the right-hand side of main page, it displays Recent Comments, Archives, Categories and Meta headings; however, how can I control what displays there?
    2) Re #1, I would like Categories to show, as it does now, but the subheading underneath says, "No categories". There ARE categories I've created when I entered my listings so why are they not showing in this area of the screen, as I would like to be able to click on them to search listings by the displayed categories (when I can figure out how to get them to display).
    3) How can I control the content of the bottom area of my pages where the theme displays the following: About Us (need to change underlying default Lorem Ipsum text), Archives Widget (not sure what this is, latest date shows 2010), Categories (seems to be hard coded as Entertainment, Technology, etc - none of which map to the actual categories I've added to my site/listings) and Search (what does this search for?). In any event, how do I manipulate this lower area of my page?
    Thanks in advance for your help!
  2. nitin
    nitin Guest
    To insert your own contents in the sidebar, just go to Dashboard-> Appearance-> Widgets and then from the Home Page Widget Area, just remove all the widgets being displayed in the section.
    Also, after removing every widget. Just drag-and-drop your desired widgets from the list of available widgets on the left and drop it to the Home Page Widget Area.
    Same you can do for the other Widget areas displayed.
    Hope this helps...!
    Nitin
