Listing Information Help
Discussion in 'HomeBuilder WordPress Theme' started by v4sb, Nov 20, 2015.
  1. v4sb
    v4sb Member
    Okay, on the home page, where it shows the latest listings, the "bedroom" area shows the correct information and label. See attached photo of the correct label.
    However, when you click on the listing, the "bedroom" label changes to something else. This label should still say "bedroom".
    Can you fix this error? I have provided photos of the correct label and then where it shows it incorrectly on the actual property listing (post) page. Thank you.
    [​IMG][​IMG]
  2. nitin
    nitin Guest
    To look into your error and to fix it, we require access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password
    We will try to get your issue resolved as soon as possible.
    Nitin
