Is there any way to embed my Geocraft or wordpress web into a div of my HTML page? Using jquery for example? I need to insert my wordpress page into a div in the main html page And insert specific divs ? THANKS!!!!!
Hello, You can achieve it with the help of code given below. Just add your page address in it. Code: <div style="margin: 0 auto; width:100%; height:400px;"> <object type="text/html" data="**URL to page**" style="width:100%; height:100%; margin:1%;"> </object> </div>
Any way to display the div on mobile devices also?? I try this code but in my screen appears 2 vertical scrolls and the height is not fullscreen .(
Hello, Code contain height tag you can increase it from there. I think this code will work for mobile devices too but it depends on where you are adding it. Please provide your page link. Then only i can check your issue.
Thanks! My link is http://www.tuguiaencastellon.es/link/ But i want to see the wordpress div and the navbar with full height My code is: <div style="margin: 0 auto; width:98%; height:400px;"> <object type="text/html" data="http://www.tuguiaencastellon.es/negociosyservicios/" style="width:100%; height:100%; margin:1%;"> </object> (i set 98% because I didnt see the vertical scroll) How can I do to set full height automatically in each screen size? (Responsive design) THANKS!
Hello, Remove old code and paste code given below. Code: <div class="inside"> <object type="text/html" data="http://www.tuguiaencastellon.es/negociosyservicios/" style="width:100%; height:100%; margin:1%;"> </object></div> After that paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .inside{ margin: 0 auto; width:98%; height:1200px; } @media only screen and (min-width: 760px) and (max-width: 959px) { .inside{ height:1200px; }} @media only screen and (min-width: 459px) and (max-width: 760px) { .inside{ height:1200px; }} @media only screen and (max-width: 459px) { .inside{ height:1200px; }} Your main theme contain code for multiple media screen. I have picked three media codes from there. This will make the trick. If not then use other media codes and try them.
