Hi! I want to localize Black Rider Pro to Russian language. I've try to do this with Poedit, but after uploading .mo file there's nothing happens. So, I've got the CodeStyling Localization plugin and tried to localize theme with it. This plugin take this error: Error: The actual loaded translation content does not match the textdomain: road-fighter Expect, that any text you translate will not occure as long as the textdomain is mismatching! This is a coding issue at the source files you try to translate, please contact the original Author and explain this mismatch. I tried to deactivate all plugins on site, but got same error. Address of site is http://time4life.biz Please help me
Hello, Follow the link given below http://www.inkthemes.com/how-to-cre...-of-wordpress-theme-in-multiple-languages/02/ I hope this will help you.
I've done all things step-by-step by this instruction, but got same error again. Actually, I've done all of this before asking this question. Waiting for your response
Hello, I think you are doing some mistake while translating the theme. Firstly deactivate the CodeStyling Localization plugin and then follow the steps again of the link given below http://www.inkthemes.com/how-to-cre...-of-wordpress-theme-in-multiple-languages/02/ Note: Carefully follow the 8th and 9th points instruction of link given above. I hope this will solve your issue.
