Many of the companies in our directory have either more than one physical location or provide their services in more than one location. For example a Bank that has physical offices in Florida and New York but also provides loans in Texas and California. Problem 1) The add a listing feature only allows one physical address to be entered. Problem 2) If a web visitor uses the location search function on the homepage, only one location will come up in the search results. Solution: 1) The ability to enter more than one physical address in the add a listing. 2) The ability to enter more than one service location area. 3) The search function on the homepage should be able to search and find more than one location or service area for any specific company listed in the directory. Please advise if any of the features listed above are currently available in the back end? If not, will they be included in the next theme update?
Hello, There is a description field in the theme. where you can add physical address if you have more then one. It can be searched easily through front page search field. Custom field don't have searchable address field option.
If I may make a suggestion, perhaps if you have a customer with several physical locations it might be worth them having several listings one for each of their locations!
