Location Map on Listing not visible?
Discussion in 'GeoCraft WordPress Theme' started by ldroberts92, Dec 15, 2015.
  1. ldroberts92
    ldroberts92 Guest
  3. brianpat
    brianpat New Member
    To use an Army expression RTFQ, The location map on the listing is not visible? On the listing not the home page.
    Brian
    I apologize for my previous reply..
    Let me tell you that map will display only for the premium listing and not for the free listing.
    So if you want to show the map on the free listing as well, you just need to follow the screenshot given below.
  5. brianpat
    brianpat New Member
    Maybe it's me, but I,m not getting any maps showing anywhere. Maybe I'm missing a plugin or something?
    Ticked the Geo Location search to on. (Get a space on the front page where the map should be)
    Correct me if I'm wrong but the premium listings whithin the example data should still show maps. Again I have Location Map title
    but underneath just an empty box where the map should be..
    Should we add a plugin or a widget or something else.
    Thanks Priyanka
    Brian
  6. ldroberts92
    ldroberts92 Guest
    I have made the changes, but the maps still do not display on the listings.
  7. ldroberts92
    ldroberts92 Guest
    Hi Brian,
    I do not have this screenshot, and currently have the updated theme. 2.0.7
    Luke :)
  8. ldroberts92
    ldroberts92 Guest
    I have attached a photo for you.
  9. rogerb
    rogerb Active Member
    On my site I have the home page listing with the map above, can't see anyway to produce this on any other listing page.
    I've never seen the map appear elsewhere or any indication that it should unless you have a third party plugin to do it for you.
    Where did you see this information? Have I missed something?
  10. brianpat
    brianpat New Member
    Hi Luke,
    Just to clarify my initial post was to ask support to answer your question as I have the same problem.
    No maps showing anywhere, even after adding a premium listing.
    Help, anyone? PLEASE
  11. brianpat
    brianpat New Member
    Hi Roger,
    To clarify I have a space on the top of the home page where the map should be. Then the other problem is at the bottom of individual listings, again
    I have a blank space where a map should go. Unlike yours here : http://www.inboston.co.uk/listing/reab-electronic-services/
    Cheers
    Brian
  12. rogerb
    OK, I understand what you mean now Brian.
    My site as far as the mapping goes is bog standard with no additions. I did need to set it up carefully with the Geomapping on, a long map centred location, several locations entered (and I did miss the text box near the bottom to enter an address for a location) and a listing using the mapping. Cache was an issue as I use a Quick cache pro plugin for site speed (temp disabled to get mapping working) and the browser cache worked differently on different browsers! It doesn't work the way everyone would like but it suits me at the moment as I concentrate on a major town and outlying villages.
    PS. Was based in Sussex and worked in Hastings many years ago by the way!
  13. rogerb
    Your description field is also missing as well on your listings - have you turned it off for free listings or something?
    I suspect you'll finish up reinstalling the theme - there's new updates quite often anyway!!!
  14. ldroberts92
    ldroberts92 Guest
    Hi Brian,
    I have turned off the description for free listings, but would still like the location map to be displayed. Any ideas?
    Luke :)
  15. brianpat
    brianpat New Member
    Hello Luke,
    Don't know if you have seen my posts above but I haven't a clue. I have the same problem as you.
    I did update the latest WP version, dont know if that is what screwed things up. Anyhoos I have submitted a ticket to support.
    If I do learn anything I will post here.
    Rogerb seems to know what he's doing looking at his cool sites. Maybe he can help you.
    Regards
    Brian
