Logo background is not transparent
Discussion in 'Local Business WordPress Theme' started by pinkmaddy, Apr 3, 2015.
  1. pinkmaddy
    pinkmaddy New Member
  2. praveen
    praveen Support Staff
    Hello, pinkmaddy!
    I have checked your website and find the logo you are using is just an empty image with white background.
    Could you please provide us the screenshot of image that you have used for the logo?
    Praveen
  3. pinkmaddy
    Is there a way to have text instead of a logo? I would like to just put the name of the business in place of a logo but I want the font to be rather large and white. Is that possible?
  4. praveen
    Hello, pinkmaddy!
    Praveen
  5. chessx
    chessx New Member
    I made you an image with your company name you can use as a placeholder till you get something better or if you're not comfortable editing like praveen suggested.
    http://tinypic.com/view.php?pic=dewxnt&s=8#.VSJq7tzF9Og Just follow link and under Tools on left hand side click Zoom. A window will open and you should see white box (its white transparent txt). Right click and select "save image as"
