Logo flush left & phone numbers on top right.
Discussion in 'Woodpecker WordPress Business Theme' started by designstouch, Jun 28, 2014.
  1. designstouch
    designstouch Member
    Hi
    How can I make the logo flush left? Currently it is align with the menu bar. Also, how can I add two location phone numbers on top heading & get rid off the tap to call button with out compromising the mobile view?
    Thanks you so much as always!
    You are asking to make changes in layout. It require customization in the header.php file.
    You can call a freelancer for it.
    I hope you can understand.
    Nitesh Raghuwanshi
  3. designstouch
    designstouch Member
    Hi Nitesh,
    I understand it.
    I would really appreciate it if could provide me the codes. I have applied the same changes (adding a phone number top right) on your colorway theme and received the code from the your support team.
    Thank you,
  4. Nitesh
    Open header.php file and add code given below as shown in the image. It will add second contact number in the header.
    </br><a class="button-def" style="margin-top:10px;" href="tel:123456789">Call:&nbsp;123456789</a>
    Add your contact number in place of "123456789"
    Shifting logo and call button to the corner require layout changes.
    Nitesh Raghuwanshi
  5. designstouch
    designstouch Member
    Thanks a lot Nitesh,
    Nitesh do you have any suggestion for freelancer?
    Thanks you Nitesh you guys are awesome!
