Hi InkThemes Community - I am looking for themes with a static top navigation menu. Like this:http://www.mgifreight.com/. The menu stays with the viewer even as you scroll down. Does InkThemes provide any themes that do this? Or which of the InkThemes themes be made to do this? Thank you!
Hi, You can use One Page theme for your requirement.. Here's the link of the theme: https://www.inkthemes.com/previews/?demo_id=505 Hope you will get it helpful... Thanks & Regards! Priyanka InkThemes.com
The static menu is present in the One Page theme by default. However, if you want to use another theme, just select the theme as per your requirement, we will implement the static menu in that theme even if it doesn't support it by default. Looking forward to hear from you Thanks & Regards! Priyanka InkThemes.com
