Since updating WP to 4.0 I no longer can select which custom menu populates the navigation bar under the header, see www.cclnwo.org. Only the Footer custom menu shows up there. Please advise.
Hello, Do you want menu appeared in footer section also show in header section?? Thanks & Regards Pramod
Header section menu is set for Top Menu, but the Footer Menu shows there. I did temporarily change the footer section menu to the Top Menu so that I had navigation somewhere.
Hello, Please provide the following information listed below. Your all threads Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] Thanks & Regards Pramod Patel
