Made Changes to Themia Pro Slider & Tagline that are not appearing
Discussion in 'InkThemes-Support Working Hours' started by dchardnett, Nov 13, 2014.
  1. dchardnett
    dchardnett New Member
    Greetings,
    I am having a challenge with my Themia Pro. I changed a slider image and the correction only shows logged into my dashboard. The same for the change I made to the Tagline. They only appear while I am logged in. However, they are not showing in different browsers on different devices, or when I log out.
    Please help Thank you.
    http://www.greatgainesfoods.com
  2. Yogesh
    Yogesh Guest
    This issue maybe because of plugin. So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
    Yogesh Bhade
  3. dchardnett
    Thank you Yogesh. I did as instructed. I deactivated all plugins; however, the changes are still not appearing.
  4. Yogesh
    Yogesh Guest
    Download a fresh copy of latest theme from members area and upload it to your website.
    That will resolve your issue.
    Yogesh Bhade
