mailicious script on poloray?
Discussion in 'Poloray WordPress Theme' started by hitechpanda, Oct 1, 2016.
  1. hitechpanda
    hitechpanda Member
    I recently helped a client to rebuild his site using this theme but the hosting company said there's a malicious script on the theme and he got a warning from his hosting company due to that issue.
    I trust Inkthemes products but I need to response back with a "developer" language so can you please clarify?
    The theme was installed in /var/www/sotisaudio.com/public_html/wp-content/themes/poloraytheme/header.php 42
    Now the hosting has switched it to default theme but I think they leave a clue on line #42 on header.php
  2. Naveen
    I have checked the theme at our end, on that line no. we found an opening <div class='container_24'> which I don't think would be a root cause of your issue.
    You are requested to do a fresh installation with the latest version of the theme which you can get from your members area.
    This will resolve your issue,
    Warm Regards!
    Naveen Kolhe
