Main Container Opacity
Discussion in 'ColorWay WordPress Theme' started by seenacs, Apr 5, 2013.
  1. seenacs
    seenacs New Member
    I'm trying to change the opacity of the main white container in the center of the pages. I've got a background image that I want to show through behind that center section.
    Can someone either provide the code to make that change, or guide me to where the code is controlling the color/design of the main container so I can make the change?
  2. seenacs
    seenacs New Member
    .container {
    background: rgba(255, 255, 255, 0.3)!important;
    .footer-container {
    background: rgba(0, 204, 0, 0.3)!important;
    .footer-navi {
    background: rgba(0, 102, 0, 0.6)!important;
    Found an older thread with similar issue, and made it work. The footer rgb is based on the green theme for those who need it.
  3. Piyush
    You can also paste the following code instead of the above code, in your Custom CSS
    .container {
    .footer-container {
    opacity: .5;!important;
    .footer-navi {
    This will work on all theme color scheme.
