Main menu and page menu not the same
Discussion in 'BusinessGrow One Page WordPress Theme' started by metalware, May 15, 2015.
  1. metalware
    metalware New Member
    Is there a way to make the main page (home) menu the same as on the sub-pages?
    See attached screen shots...
    J
  2. millmead2
    millmead2 Guest
    Can someone kindly answer this question. Regards.
  3. priya
    I would like to inform you that our BusinessGrow theme is a one-page theme and the menus settings from homepage could be done from theme option panel for various homepage sections.
    However, If you want to use paged menus on your site, it will require some source code customization in the theme, we did it at our end..
    So you are kindly suggested to contact us at our email id i.e. [email protected] along with this thread link as well and we will send you customized theme..
