Make Grid View the default listing way in homepage
Discussion in 'ClassiCraft WordPress Theme' started by anuj, Jul 10, 2013.
  1. anuj
    anuj New Member
    New Delhi
    Hello
    Please let me know how to make the grid view as the detail ad listing view in homepage
    thanks in advance
  2. careykidd
    careykidd New Member
    #bump -- How do you make Gridview the Default?
  3. spottedvarennes
    spottedvarennes Member
    quick solution, you have to modify this in the template files (index.php and template_cate.php. In those file you'll see a javascript function when the DOm document is ready, you need to add this code
    so the javascript will click the gridView for you
    simply add this after the function (look for it in the code below)
    jQuery('#gridview').click();
        <script type="text/javascript">
            jQuery(document).ready(function ($) {
                $("a.switcher").bind("click", function (e) {
                    e.preventDefault();
                    var theid = $(this).attr("id");
                    var theproducts = $("ul#products");
                    var classNames = $(this).attr('class').split(' ');
                    var postmeta = $(".post_meta");
                    var text = $(".contents p");
                    var gridthumb = "images/products/grid-default-thumb.png";
                    var listthumb = "images/products/list-default-thumb.png";
                    if ($(this).hasClass("active")) {
                        // if currently clicked button has the active class
                        // then we do nothing!
                        return false;
                    } else {
                        // otherwise we are clicking on the inactive button
                        // and in the process of switching views!
                        if (theid == "gridview") {
                            $(this).addClass("active");
                            $("#listview").removeClass("active");
                            $("#listview").children("img").attr("src", "images/list-view.png");
                            var theimg = $(this).children("img");
                            theimg.attr("src", "images/grid-view-active.png");
                            // remove the list class and change to grid
                            theproducts.removeClass("list");
                            theproducts.addClass("grid");
                            //$('.rating').hide();
                            postmeta.hide();
                            text.hide();
                            // update all thumbnails to larger size
                            //$("img.thumb").attr("src",gridthumb);
                        else if (theid == "listview") {
                            $("#gridview").removeClass("active");
                        //    $('.rating').show();
                            $("#gridview").children("img").attr("src", "images/grid-view.png");
                            theimg.attr("src", "images/list-view-active.png");
                            postmeta.show();
                            text.show();
                            // remove the grid view and change to list
                            theproducts.removeClass("grid")
                            theproducts.addClass("list");
                            // update all thumbnails to smaller size
                            //$("img.thumb").attr("src",listthumb);
        </script>
  4. careykidd
    does this still work?? I updated my theme and forgot to do a child theme.. this doesn't seem to be working for me anymore
  5. careykidd
