Make Menu, Textbox, and Call box more transparent?
Discussion in 'RoadFighter WordPress Theme' started by gdfred, Aug 1, 2013.
  1. gdfred
    gdfred New Member
    Is there a CSS code that will make these overlay backgrounds more transparent? Say 50% or 75% transparent?
    Also is there a way to re-position these boxes? Or have them fade in or 'slide' up onto the main image field?
    Thanks.
    For the background tranparent issue,
    Paste the code given below in Custom CSS
    .menu-wrapper {
    background: rgba(255,255,255,.5);
    .flex-caption {
    opacity: .5;
    .header_wrapper .call-us {
    opacity: .5;
    For the re-position issue,
    .menu-wrapper {
    margin-top: 25px;
    .header_wrapper {
    margin-top: 37px;
    .flex-caption {
    position: absolute;
    right: 12%;
    bottom: 40px;
    You can adjust the values of margin-top, right and bottom as per your requirement.
  3. gdfred
    gdfred New Member
    Thanks. Is it possible to move the menu bar to near the top of the slider and place the logo and call box below it?
  4. Gourav
    Go to header.php present in your theme directory and follow the instruction as shown in image given below
  5. johnstonkmm
    johnstonkmm New Member
    Thanks for the support and the questions. I tried them and it worked perfect! Thanks
  6. gdfred
    gdfred New Member
    Hi Gourva and Piyush,
    I am kind of new to WP and I do not know where to find the "header.php" file or the "theme directory" from within Wordpress. Can you tell me how to find the theme directory? Thank you. I appreciate all the support you guys give.
    Greg
  7. gdfred
    gdfred New Member
    I figured out how to edit the header.php file in Wordpress. If anyone else needs to know you can get there via:
    Dashboard>Appearance>Themes>Editor and select the .php file you want to edit...
    (Before I edited, I saved an original copy of the hearder.php file text with notepad, just in case I created a glitch and needed to go backwards!)
    Thanks again to the support team! I knew it was the weekend. So I went searching on the wordpress.org site.
