Making default URL as home directory
Discussion in 'VideoCraft WordPress Theme' started by mar268, Aug 15, 2014.
  1. mar268
    mar268 New Member
    After installing wordpress along with the VideoCraft theme onto the live server, I tried to make default web URL as home directory(www.highstreetvideos.com) instead of (www.highstreetvideos.com/wordpress) by following the steps on the wordpress site. Everything works except the "SignIn" and "Add Video" menu items. The links underneath still point to (/wordpress). Can you please tell me how to change them ?
    Thank you.
    Aravind
  2. Yogesh
    Yogesh Guest
    Go to --> dashboard --> Setting --> General -->Site Address (URL)
    and enter your site url www.highstreetvideos.com
    as shown in screenshot
    Yogesh Bhade
      File size:
      64.3 KB
      3
  3. mar268
    mar268 New Member
    Hi Yogesh,
    I had done that since it was part of the instructions on the wordpress site (to move a wordpress website to home directory )(attaching screenshot).But the issue is still there. It is only SignIn and Add Video button whose underlying links were not updated. Is there anyway in the theme I can change this.
    Thank you for your help.
    Aravind
  4. Yogesh
    Yogesh Guest
    There is no way to do it in theme.
    Can you please tell me in which directory you installed wordpress?
    Yogesh Bhade
  5. mar268
    mar268 New Member
    Hi Yogesh,
    I have re-done the whole process and now I can see the signin URL is pointing correctly to the link without "/wordpress". But now when I try to login the login page does not go anywhere and returns back to the sign in screen.
    When I set WP_DEBUG=true I see the following text coming in the user id text box.
    Notice: Undefined variable: user_login in /var/www/vhosts/highstreetvideos.com/httpdocs/wordpress/wp-content/themes/videocrafttheme/functions/registration_panel/login.php on line 44
    Thank you.
    Aravind
  6. Yogesh
    Yogesh Guest
    I think you need to reinstall the theme.
    Yogesh Bhade
  7. mar268
    mar268 New Member
    Hi Yogesh,
    Is it possible to install the theme without being able to sign in ?
    Thank you.
    Aravind
  8. Pramod
    Pramod Guest
    Unfortunately there isn't a way to do that.
    Pramod
