Hi there, Is it possible to make certain fields of MY CHOICE mandatory for clients to fill in before submitting their message? I looked around the forum and there are several old posts about the same issue but could not find any solution anywhere. I am running on version 1.1.4 Thank you
Hello David, It is possible to add, remove and change order of the form fields. But not possible to set field of choice required. Thanks & Regards Nitesh Raghuwanshi
