Manually Add Subsriptions
Discussion in 'InkMember WordPress Plugin' started by lidgmbh, Mar 27, 2016.
  1. lidgmbh
    lidgmbh New Member
    i want to add some user manually to a product.
    On the user-profile page, there are checkboxes for the single products, but when I activate and try to save them, the plugin won`t accept it (Message is: Subscription ist expired).
    How can i solve this?
