Map issue
Discussion in 'GeoCraft WordPress Theme' started by johnslaytor, Nov 28, 2012.
  1. johnslaytor
    johnslaytor New Member
    Despite three listings having the same address, only one of them shows the map. Allwere created the same way and when creating the listing, all showed the map correctly. It was only when they were posted the map for two of them failed to appear.
    Here are the three listings - the first shows the map
    http://coffeedirectory.com.au/listing/g-s-roasting/
    http://coffeedirectory.com.au/listi...eaker-for-food-and-beverage-franchise-chains/
    http://coffeedirectory.com.au/listing/mutch-and-moore-coffee-courses/
  2. Krish
    Krish Support Staff
    India
    Please send your dashboard details with this tread link. We will solve your issue.
  3. johnslaytor
    thanks Krish
    how do I send my dashboard details without the world seeing my password? i.e. how do I privately message you?
  4. cdllife
    cdllife New Member
    If you click inbox by your username you can start a new conversation and add participants.
  5. johnslaytor
    thanks for fixing it - was it a problem my end or a bug?
  6. Krish
    Krish Support Staff
    India
    I have fixed this issue. For future use, i added some guidelines screenshot of map
