Map not working after upgrade
Discussion in 'GeoCraft WordPress Theme' started by rogerb, Jul 17, 2016.
  1. rogerb
    rogerb Active Member
    Oh dear, upgraded to v2.0.9, inserted api detail and it all worked for a short time but now does not display the map or pins just a blank area as shown in screenshot attached!
    Hi, Rogerb..
    Would you please send us your dashboard details at [email protected] along with this thread link so that we can resolve your issue..?
  3. rogerb
    Thanks for the details..
  5. rogerb
    Any news on this as I've had to turn the geo mapping off for the moment!
  6. priya
    Hi, Rogerb..
    We have forwarded your issue to developers department and they will get back to you ASAP..
  7. rogerb
  8. priya
    Your issue has been resolved and we sent you an email regarding this as well...
    Kindly check your email..
  9. polros
    polros New Member
    I ´ve been investigating about this: Is not a problem form your URL. I think Ink Themes support should be noticed about this issue and give us a solution. This is the problem:
    If you are using the Google Maps API on localhost or your domain was not active prior to June 22nd, 2016, it will require a key going forward.
    You shoud get a GOOGLE MAP API Key and insert it in some Geocraft file. I really spend a lot of time trying to locate that file but i couldnt. I also installed a plugin for this but, didn´t work neither.
    Check this article: https://www.latecnosfera.com/2016/06/google-maps-api-error-missing-keymap-error-solved.html
    So, until Ink Theme Team tell us where is that file or what should we do, we will have a Geocraft directory without map, sounds great right? !
  10. nitin
    nitin Guest
    I would like to inform you that, google has recently updated its Map API and it will work only with a proper Map API key.
    We have already updated our theme with the required functionality, you can check the theme's changelog from here:
    https://www.inkthemes.com/community/threads/geocraft-theme-v-2-0-9-is-available.18853/
    You are requested to create a proper Javascript Map API key with your domain authentication from here:
    https://developers.google.com/maps/documentation/javascript/get-api-key
    and use it in the specified area under theme options of our updated version of the theme see: http://screenpresso.com/=jurTe
    Your map will start appearing and will work fine.
    Please create the key and use it as mentioned above.
    Nitin
    InkThemes.com a
