I cant get the map working .I see there are alot of issues with this please send instructions I will attempt to fix.
Hi, Greetings from InkThemes! Could you please provide us 'URL' of your site so that we can better assist you? Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
I ´ve been investigating about this: Is not a problem form your URL. I think Ink Themes support should be noticed about this issue and give us a solution. This is the problem: If you are using the Google Maps API on localhost or your domain was not active prior to June 22nd, 2016, it will require a key going forward. You shoud get a GOOGLE MAP API Key and insert it in some Geocraft file. I really spend a lot of time trying to locate that file but i couldnt. I also installed a plugin for this but, didn´t work neither. Check this article: https://www.latecnosfera.com/2016/06/google-maps-api-error-missing-keymap-error-solved.html So, until Ink Theme Team tell us where is that file or what should we do, we will have a Geocraft directory without map, sounds great right? !
Hi, Greetings from InkThemes, I would like to inform you that, google has recently updated its Map API and it will work only with a proper Map API key. We have already updated our theme with the required functionality, you can check the theme's changelog from here: https://www.inkthemes.com/community/threads/geocraft-theme-v-2-0-9-is-available.18853/ You are requested to create a proper Javascript Map API key with your domain authentication from here: https://developers.google.com/maps/documentation/javascript/get-api-key and use it in the specified area under theme options of our updated version of the theme see: http://screenpresso.com/=jurTe Your map will start appearing and will work fine. Please create the key and use it as mentioned above. Thanks & Regards! Nitin InkThemes.com a
Hi, Greetings from InkThemes, We have re-checked the link and found everything working. You can follow the same link below:- https://developers.google.com/maps/documentation/javascript/get-api-key Thanks & Regards! Nitin InkThemes.com
Hi. It's not that link. The screenpress pro link. See screen shot below. For the page that displays for http://screenpresso.com/=jurTe
Hi, I got your concern. I have attached the same image here. Please check. Hope this helps...! Thanks & Regards! Nitin InkThemes.com
