Mapping versus Non Mapping page load speed!
Discussion in 'GeoCraft WordPress Theme' started by rogerb, Jan 5, 2016.
  1. rogerb
    rogerb Active Member
    Has anyone done any tests to check page load speed on this feature.
    My site is on a VPS and if I turn on mapping it takes much longer to load the page than with it off.
    I've turned it off for the moment while I check whats happening as it takes 10 times longer to load the front page when populating the map - I have around 160 listings with photographs and locations entered.
  2. joshuasloan
    joshuasloan Member
    Is it only the Map? I know of a couple image optimization plugins that have worked well on other sites to increase load time.
  3. joshuasloan
    joshuasloan Member
    https://gtmetrix.com/ is a useful free tool, kind of been afraid to run it on my GeoCraft development site to be honest...but the InkTheme developers should use it to make their code better/smarter/faster.
    Thanks Joshuasloan for your suggestion....
    Rogerb,
    You can use the plugin to get rid of your issue...
    Here are some plugins and their links which may help you for your purpose..., please have a look.
    WP Minify: https://wordpress.org/plugins/wp-minify/
    Better WordPress Minify: https://wordpress.org/plugins/bwp-minify/
    WP Super Minify: https://wordpress.org/plugins/wp-super-minify/
    Note: These plugins will combine and minify your CSS and JS files to improve page load time..
    Hope you will find it helpful..
  5. rogerb
    Thanks all, I'll try some of them out.
    At the moment I'm trying WP Super Cache as it allows preloading and seems to make a substantial difference!
