Hi again. I have a menu tab labeled "rooms" and under "rooms" are the various rooms listed in a drop down. So for example, "blue room", "red room", "green room". I would like to make it so that a person cannot click the main tab "rooms", but will only be allowed to click one of the items from the drop down menu. How do I do this? Thank you.
Never mind, solved. For anyone else wanting to know, you just replace the http:// link with the "#" in your custom menu. Thank you.
Wait! I sort of fixed it, but not completely. I was able to accomplish what I wanted; however, now if I am in the 'blue room' (which was listed as a subpage/menu under 'rooms'), now on the dropdown menu whatever room I am in, the menu box for that particular room in the drop down does not have a solid background? Can I fix it so that the drop down menu will show a solid background again? I hope my question makes sense.
Hello, Could you please specify your issue with the help of screenshot images and also share your website link.
