Menu and other Typefaces
Discussion in 'Squirrel WordPress Theme' started by joey, Dec 21, 2013.
  1. joey
    joey New Member
    Three questions for Squirrel Theme Pro:
    1. The navigation menu appears in All Caps. How to I change this to simply capitalize the first letter?
    2. I would like to use the same font throughout the entire site - headings, slider heading, menu, body, etc… How do I do this?
    3. Lastly, when I remove the 1st and 2nd headings, leaves white space between the slider and menu. How do I eliminate this? (see attached)
    Thanks!
    Paste this code in Custom CSS
    #menu .ddsmoothmenu li a {
    text-transform: capitalize;
    2.Go to js > custom.js present in your theme directory and remove the code given below
    //cufone
    Cufon.replace({
        hover: true
    })('#colRight h2')('.reply',{
        hover:true
    })('h1')('h2')('h3')('h4')('h5')('h6');
    Now,
    h1, h2, h3, h4, h5, h6, p, a, span{
    font-family:symbol!important;
    Inplace of "symbol" put your font type.
    3.
    .menu_wrapper ul {
    margin-bottom: 0;
    .slider-info {
    margin-top: 0;
    #slides {
    position: absolute;
    top: 0;
  3. joey
    joey New Member
    Regarding #2:
    While that works for the body copy, unfortunately the Slider and Full Width col headings remain unchanged. I would really like to change theses to something else (and the titles/heading on each page). Can you let me know?
    Basically I don't want this font to show up anywhere on my site. It just doesn't fit.
    Thank you :)
  4. Piyush
  5. joey
    joey New Member
    the font appears twice on the homepage and then as the 'title' on pages (About, Testimonials, etc)
  6. Piyush
    We have checked your website it seems that you haven't remove the cufone code from the custom.js file
    due to which the above given code are not working.
    So please go to js directory > custom.js file present in your theme directory and remove the code given below
    //cufone
    Cufon.replace({
        hover: true
        hover:true
    Could you please explain your issue little more and specify the issue with the help of screenshot images.
  7. joey
    joey New Member
    I actually have removed it. Days ago.
    These are the fonts I'm talking about:
    Full Col Heading, Slider Heading, and Page Titles. See attached
  8. Piyush
    .slider-info h1 {
    font-family: symbol! important;
    font-size: 20px;
    text-shadow: none;
    .index-fullwidth h3 {
    font-size: 18px;
    text-shadow: none;
    h1.page_title {
    In place of "symbol" you can put your font.
